Discontinuous
Old   February 27, 2006, 16:54
Default Discontinuous
Noname
What is the difference between galerkin and discontinuous galerkin methods.
Old   February 28, 2006, 02:18
Default Re: Discontinuous
Yves
Classic Galerkin enforce continuity from one element to the next one. In each node, a variable has a unique value. If you use linear elements, there is continuity of the variable solved for, but not of its derivative. Using higher order elements, you can enforce that.
Discontinuous Galerkin doesn't enforce such continuity between elements. The method allows for different values in neighbouring elements at the same physical location. Usually though, for good accuracy, the jump across an interface is (very) small. In the end there has to be a way to couple the solution in the different elements, this is done by solving a Riemann problem.
Old   February 28, 2006, 07:26
Mich
What paper you may offer for the first acquaintance?
Old   February 28, 2006, 12:01
Yves
A good introduction would be the online course of Tim Warburton. http://www.caam.rice.edu/~timwar/MA578S03/MA578.html
If you want a single file to look at you read the notes from Bernardo Cockburn. http://www.math.umn.edu/~cockburn/LectureNotes.html
Both are DG experts.
Fluent UDF Discontinuous Motion lequi7 Fluent UDF and Scheme Programming 2 November 3, 2011 23:18
Discontinuous Galerkin schemes -- fortran source code diedro Main CFD Forum 3 March 12, 2011 10:20
Discontinuous Galerkin method Troy Main CFD Forum 1 October 29, 2007 03:27
discontinuous contour for internal wall? Orca.Fight CFX 1 August 17, 2005 10:40
Discontinuous Galerkin finite element method Tony Main CFD Forum 0 May 27, 2003 18:48
