June 26, 2020, 07:47 |
Meshing on Curved Edges
MA
Rep Power: 6 |
Hi everyone,
I have meshed a blade in STARCCM+ while using the curve control that includes the featured edges (after computing the curves). Further, I tried to change the surface curvature Pts i.e. 72, 90, 120, 144 out of Max. Pts 200. Also, used both distribution modes in Prism Layer Mesher i.e. Hyperbolic Tangent and Geometric Progression. Refined the mesh, it gives me the Y+ between 1-5 everywhere except those curved edges and the tip of the blade with high skewness (refer the attachments). Maximum boundary skewness angle = 8.4891171903e+01 deg Maximum skewness angle = 8.7806950619e+01 deg (for entire domain) Could you please suggest how to improve the mesh quality on these curved parts? P.S: I am using Surface Remesher+Polyhedral+Prism Layer Mesher. However, surface curvature refinement is enabled in surface remesher. Recently, tried with field function refinement but it gets stuck at "getting candidate vertices". Thanks for your time. Best regards, |
meshing 3d, starccm+ |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[ANSYS Meshing] Meshing fluid around sharp edges of a 3D insect wing. | minglis | ANSYS Meshing & Geometry | 1 | February 2, 2017 09:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Meshing curved corner for FLUENT 4 | Hakeem | FLUENT | 2 | October 16, 2000 18:29 |
