inlet boundary condition
Old   August 5, 1999, 06:26
Default inlet boundary condition
abdul aziz jaafar
Dear respectful friend
I am a beginner in CFD, working on rotating flow. I have got problem of specifying the inlet boundary condition.
In experimental rig that I have examined. The air enter inter into the system through nozzle, and the inlet has the tangential, radial and axial components.
I am solving axisymmetric flow using an orthogonal grid arrangement. The mass is obtained directly from measurement, and is used to spesify the velocity components at the inlet. I should mentioned here that the air coming with high tangential velocity.
For computations, I need to include the mass flux for corresponding pressure correction equation / I referred here as the countinuity equation.
I am very grateful if any of you can advice how to calculate the correct mass flux for the inlet
Thank you
Abdul Aziz Jaafar
Old   August 5, 1999, 16:56
Default Re: inlet boundary condition
abdul aziz jaafar
Dear all
It seem that I havent got any response for this simple question. Anyway thank you. I just want to mention that I to implement the inlet condition is quite tricky and it is not simple as it thought. It is included my understanding on how solution prosedure take place.
Abdul Aziz Jaafar
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
