April 13, 2006, 10:15 |
Spectral (finite) volume method
Hi everyone
I have read a some papers about this (I think new) discretization method. For an example look: Sun, Wang, Liu "Spectral (finite) volume method for conservation laws on unstructured grids. VI: Extension to viscous flow" J. Comp. Phys., vol 215. p 41-56, (2006) Has someone already tested it? Can you give some opinions about it? It looks so attractive, although it is still a young method... Thanks Max |
April 13, 2006, 11:11 |
Re: Spectral (finite) volume method
Dear Max,
I have not read about this new paper yet.. However, I recall there was a lot of work on Spectral finite element (which also works on unstructured grids) from the MIT group lead by Anthony Patera in the 1980-90's.. At some point, there was a commercial code (NEKTON) which used the methodology as well.. The algorithm was (as I recalled) used for a lot of transient /unsteady laminar flow studies. I also saw a few non-newtoniand flows cases as well. However, I do not recall how much turbulence flow calculation were done using two-equations/RANS models for industrial cases.. Perhaps, they always did it via DNS.. If you find additional information, keep us posted .. Thanks, Juan Carlos |
gradient calculation of cell centered finite volume method | zhengjg | Main CFD Forum | 10 | November 11, 2012 23:13 |
References for the finite volume method on unstructured grids | old newbie | Main CFD Forum | 1 | April 25, 2011 23:53 |
water hammer solution by finite volume method | A.Maleki | Main CFD Forum | 1 | January 20, 2010 20:46 |
QUESTION in finite volume method | jack | Main CFD Forum | 9 | September 10, 2007 05:06 |
Sparse linear systems in finite volume method | Lionel S. | Main CFD Forum | 6 | January 19, 2007 10:04 |
