March 11, 2014, 06:31 |
#41 |
Philipp
Rep Power: 26 |
Ok... I get them from ICEM. What do you use for meshing?
The skeleton ran out of shampoo in the shower. |
March 11, 2014, 06:33 |
#42 |
Aqua
Rep Power: 14 |
March 11, 2014, 06:34 |
#43 |
Philipp
Rep Power: 26 |
Sorry, I don't know anything about Starccm, maybe people in the sub-forum can help you...
March 11, 2014, 06:38 |
#44 |
Aqua
Rep Power: 14 |
March 11, 2014, 06:40 |
#45 | |
Aqua
Rep Power: 14 |
Thank you for your kind reply. But regardless, to calculate d+, the width or length of the cell is needed, so : how to get that information from the software? I am using Starccm+, do you have any clue? I just asked RodriguezFatz how to get it from ICEM..
Thank you ! Aqua Quote:
#46 |
Philipp
Rep Power: 26 |
Do you use blocking/hexa for meshing?
March 11, 2014, 06:41 |
#47 |
Aqua
Rep Power: 14 |
March 11, 2014, 06:44 |
#48 |
Philipp
Rep Power: 26 |
Then you just need to go to the relevant edge (parallel to the surface) and read the sizing of the cells.
March 11, 2014, 06:48 |
#49 |
Aqua
Rep Power: 14 |
And then? I mean, each cell has its size, and its own local friction velocity. Then the next step should be to calculate the d+ by the size of the cell and its local friction velocity, which should be gained from CFX or Fluent. How do you combine the two factor: size and friction velocity? (my geometry is complex, so the size and local friction velocity vary a lot..)
March 11, 2014, 06:49 |
#50 |
Philipp
Rep Power: 26 |
Ok, if they vary strongly then you are doomed. Maybe you can create a custom function in Fluent? Is dx and dz available in Fluent?
March 11, 2014, 06:55 |
#51 |
Aqua
Rep Power: 14 |
March 11, 2014, 07:19 |
#52 |
Ok let's clarify the issue. You are using starccm+. We (me and Philip, i guess) usually use Fluent. You should give first a look at what are the plotting options in your solver. Are you sure there is no section related to the geometry of the cell? In Fluent, for example, you have:
x,y,z centroid coordinates face area magnitudes cell volumes etc. In some cases, with proper insight, you can manage a proper combination of cell parameters to finally obtain the formula proposed by Philip. Now, let us suppose you don't have such information. Then you necessarily have to go in the mesh generator (ICEM, as i understood) and retrieve the local information you are looking for. However, note that: 1) If your grid has such a variability that a representative grid parameter cannot be evaluated for a given zone then probably it has also little sense to try to obtain it. 2) You still have the y+ value. I can hardly imagine a wall parallel spacing which has so large variations to make even a guess completely meaningless. 3) More often than not you just need approximate maximum and minimum values, which means guessing maximum and minimum grid spacings in the wall-parallel directions. Also, you usually have a guess of the required spacing (say, dx+<50-60, dz+ < 30). If a rough check cannot give you insight on correctness of the spacing, then probably you are already far from the correct one. 4) If there is such variability to make this evaluation impossible, there is possibly much more to check than just these values. Indeed, these values are just a little part of the picture for selected kind of flows (wall bounded, possibly in equilibrium). In particular, choosing the wall shear stress as relevant quantity to nondimensionalize the grid spacing implies that it actually is a relevant quantity to do the job. If the flow is so complex that a relevant quantity is not identifiable then the effort to produce such d+ values is not worth it. |
March 11, 2014, 07:26 |
#53 |
Philipp
Rep Power: 26 |
This sounds perfect. Sorry aqua I am too buisy and had such short comments only!
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 12:39 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 11:51 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 22:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
