3-D turbulence model with wall function
Old   May 15, 2006, 11:09
Default 3-D turbulence model with wall function
Henry
Hello everyone:
I am working on the 3-D turbulence model with wall function. I am confused how to implement the wall function in the 3-D problem. It seems quite different from 2-D problem. I don't know how to get the two components of velocity parallel to the wall since what we get from the wall function is the total velocity (or shear stress) and we don't know the velocity direction. Could anyone help me out?
Thanks a lot in advance.
Henry
Old   May 16, 2006, 18:20
Default No people know it ?
Henry
I believe there must me some people familiar with this problem if you use wall function in 3-D problems. I will be very appreciated if anyone could give me some hints about it.
Thanks.
Henry
Old   May 17, 2006, 04:37
Default Re: No people know it ?
Halim
Read Dr. M. Peric's Ph.D thesis. "A finite volume method for the prediction of three-dimensional fluid flow in complex ducts" page 138-143. The University of London, Imperial College 1985.
I hope this helps,
Halim
Old   May 17, 2006, 14:59
Henry
Thank you, Halim. I am afraid that I couldn't get the paper since it is a thesis not a public publication paper. Anyway, I hope someday I could read it. Is there any other idea?
Thanks again.
Henry
Old   May 17, 2006, 23:55
Halim
I think you are eager to read it. Post your email or home address. I will copy or scan that portion of thesis and I will send it to you.
Old   May 18, 2006, 18:03
Henry
Hi Halim, Thank you very much! my email is "dragon8540@yahoo.com".
Regards,
Henry
Old   May 18, 2006, 22:57
Halim
Check your email-box.
Good Luck!
Old   May 19, 2006, 10:40
Henry
I got it, thank you so much.
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 11:31
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Implementation of wall function with SA model Bala Main CFD Forum 0 October 7, 2004 23:54
