Implementation of pressure-inlet for FVM
Old   May 20, 2006, 23:22
Default Implementation of pressure-inlet for FVM
Yang
hi,
I develop a program using Finite Volume Method(FVM). I need implement the pressure-inlet boundary conditions. Who knows,or has the source code about pressure-inlet for FVM? Looking forward to your replies.Thanks! Yang
Old   May 21, 2006, 16:25
Default Re: Implementation of pressure-inlet for FVM
ramp
Hi !!
first derivative of pressure normal to the boundary equals to zero.
(\partial p)/ (\partial n)=0
for all boundaries except the outflow. At the outflow specify p=0.
With these conditions, you will get the pseudo-pressure. This will, however, not affect the correctness of the velocity field. The actual pressure boundary conditions are complicated, so it is best to use the pseudo-pressure field to compute the velocity field and then solve the pressure Poisson equation to get the actual pressure if, and when, necessary.
Old   May 30, 2006, 23:10
zhang
The inlet velocity is usually assumed as time constant. So, the pressure boundary condition on the inlet can be derived from the NSE as, for incompressible flows: gradient_pressure=-rho*g+rho*vieo*Laplacian_velocity
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 21:32
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
about pressure inlet boundary Sastry(CFD Forum) FLUENT 0 February 19, 2007 02:55
