force to wait MATLAB for running parallel fluent in batch mode |
December 5, 2012, 06:42 |
Hi friends
I use Matlab to rus fluent in batch mode and in just one processor with following command ! C:\Fluent.Inc\ntbin\ntx86\fluent.exe 2ddp -g -wait -i "D:\firstcode\fluentjournal.txt" and it works very well for running fluent in four processor I use another command ! C:\Fluent.Inc\ntbin\ntx86\fluent.exe 2ddp -g -t4 -wait -i "D:\first code\fluentjournal.txt" but this command does not work I find out that the problem is related to "-wait" in other words by vanishing "-wait" the command will work so ! C:\Fluent.Inc\ntbin\ntx86\fluent.exe 2ddp -g -t4 -i "D:\first code\fluentjournal.txt" will work but: I need Matlab waits when fluent is doing its job How can I run fluent in batch mode in four processor and Matlab waits when fluent is running. |
May 9, 2013, 16:44 |
Sorin Munteanu
Rep Power: 14 |
Hi Latifi
It would recommend connecting with Fluent running in server mode (Fluent aaS). This way you should be able to connect intimately with Fluent from Matlab. With the exception of one command all Matlab calls to Fluent are synchronous (Matlab waits when Fluent is running). You can refer to my post at http://www.ansys-blog.com/tag/matlab for start-up information. Please let me know if you need more details. Sorin |
fluent 12.1, batch mode in linux | sakalido | FLUENT | 13 | September 27, 2017 08:55 |
Fluent Batch Mode - TUI | Diane | FLUENT | 13 | June 3, 2014 05:11 |
PROBLEM in UDF on parallel fluent mode | rakadit | Fluent UDF and Scheme Programming | 0 | July 13, 2012 06:51 |
fluent stops batch mode on error | Ralf Schmidt | FLUENT | 1 | March 1, 2008 10:35 |
Some help simulating Magnus Force using Fluent | Michele Spinolo | FLUENT | 6 | June 27, 2002 12:57 |
