Mass Flow rate in spray water modeling
Prev Previous Post   Next Post Next
Old   June 8, 2013, 15:48
Default Mass Flow rate in spray water modeling
behnam
Behnam Ghadimi is on a distinguished road
Hi
I am running a spray simulation using FLUENT in which a cold water injects through a hot air stream.the geometry is a rectangular channel and there is an injection in the middle of the channel.
I did the modeling using following conditions:
1) Air mass flow rate (main flow) =1.165 kg/s
2) injected water mass flow rate =0.5 kg/s
3) water injection was modeled using particle injection modeling.
3)Exit is pressure outlet.
In the post processing, it shows after very well convergence,
Mass inlet = 1.165 kg/s
Mass outlet= -1.165 kg/s
It seems that the Injected water mass is not added to the main flow.
Should I have to change or use some other models?
If anybody have any useful advice I will appreciate.
Thank you in advance
Behnam Ghadimi is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
2D axisymmetric mass flow rate for the plain orifice atomizer jwillie2000 FLUENT 2 September 17, 2010 05:43
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
