June 28, 2013, 03:51 |
reversed flow
steven
Rep Power: 12 |
hello everyone,
my cas is a 'T' tube connected by two cylindres with an inlet and 2 outlet. the fluide is turbulent. i made the boundary condition as 'outflow', the warning came to me was "reversed flow". i looked for the former thread, it is said that i could change it to 'pressure outlet'. after operation, the warning is always "reversed flow". does someone know what happened? thank you steven |
June 28, 2013, 06:33 |
Maxime Perelli
Rep Power: 41 |
you have a vortex crossing the outlet.
It is just a warning, let iterate, the warning may disappear
In memory of my friend Hervé: CFD engineer & freerider |
June 28, 2013, 06:36 |
allan thomson
Extend your computational domain at the outlets, i.e. ensure that the outlet is far away from the tee
June 28, 2013, 07:48 |
steven
Rep Power: 12 |
June 28, 2013, 07:46 |
steven
Rep Power: 12 |
Ok, thank you, i will wait a bit.
June 28, 2013, 07:54 |
#6 | |
steven
Rep Power: 12 |
https://www.dropbox.com/s/30deqc29eq...ed%20flow.docx |
June 28, 2013, 08:44 |
#7 | |
Maxime Perelli
Rep Power: 41 |
-check Mesh -how are your turbulent bc?
June 28, 2013, 08:58 |
#8 | |
steven
Rep Power: 12 |
June 28, 2013, 09:19 |
Maxime Perelli
Rep Power: 41 |
-what is the quality of worst element? (show worst element option in gambit)
-what are the tubulent bc at your inlet (you showed the turbulent model) -did you scaled your model? -can you copy and paste the output from checkMesh
June 28, 2013, 09:46 |
#10 | |
steven
Rep Power: 12 |
https://www.dropbox.com/s/xml8ctvagskchbf/0628-2.docx Mesh Quality: Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality. Minimum Orthogonal Quality = 2.75142e-01 Maximum Aspect Ratio = 1.61014e+01 |
June 28, 2013, 09:50 |
#11 |
Maxime Perelli
Rep Power: 41 |
ok, your mesh is ok and seems to be scaled
in the velocity BC, you should have turbulent parameters, waht do you have? How is you material? density, viscosity?
June 28, 2013, 10:01 |
#12 |
steven
Rep Power: 12 |
i have the parameters of K and epsilon. k=0.053985 and epsilon=1.4722. the velocity is 5m/s, it is calculated with the Re=100000. the material is water-liquid. density is about 1000kg/m3, and viscosity is about 0.001kg/m-s
June 28, 2013, 10:15 |
#13 |
Maxime Perelli
Rep Power: 41 |
Ok I have to hurry
Try to switch with realizable-kepsilon Try with and without enhanced wall treatment
June 28, 2013, 10:21 |
#14 |
steven
Rep Power: 12 |
sorry, i didn't understand what you mean 'realizable-kepsilon'. the k,epsilon values that i used are also calculated with Re=100000.
June 28, 2013, 10:43 |
#15 |
Maxime Perelli
Rep Power: 41 |
Other turbulence model
July 2, 2013, 03:33 |
#16 |
steven
Rep Power: 12 |
July 2, 2013, 05:12 |
#17 |
rayan
Rep Power: 12 |
I have same problem and I think it is the boundary conditions imposed on your two outputs which poses the problem .. when you have two output can not impose "pressure" at outlet.. What are your boundary conditions at the outlets?? |
July 2, 2013, 05:24 |
#18 |
steven
Rep Power: 12 |
I use outflow as the BC of outlet. in fact, i had wanted to try the pressure outlet, but i don't know the factors that i have to fill
July 2, 2013, 08:20 |
#19 |
rayan
Rep Power: 12 |
The condition of pressure outlet is valid when we have "one outlet" for two and more of outlet this condition is not valid, you must use the "equal flow rate" at outlets.. try to reduce the underelaxation at the minimum (0.1 or 0.2)
July 2, 2013, 08:23 |
#20 |
steven
Rep Power: 12 |
so what should I put as the gauge pressure?
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] | NormalVector | ANSYS | 1 | May 15, 2012 23:50 |
Reversed Flow for a tenth slice of a rotor | neptunemmx | FLUENT | 10 | January 30, 2012 13:51 |
Reversed flow...>>>Please HELP...! | sushii | FLUENT | 14 | October 29, 2007 04:27 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
reversed flow | Sastry | FLUENT | 5 | March 22, 2007 08:05 |
