reversed flow
Old   June 28, 2013, 03:51
Default reversed flow
steven
steven1 is on a distinguished road
hello everyone,
my cas is a 'T' tube connected by two cylindres with an inlet and 2 outlet.
the fluide is turbulent. i made the boundary condition as 'outflow', the warning came to me was "reversed flow". i looked for the former thread, it is said that i could change it to 'pressure outlet'. after operation, the warning is always "reversed flow".
does someone know what happened?
thank you
steven
steven1 is offline   Reply With Quote
Old   June 28, 2013, 06:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you have a vortex crossing the outlet.
It is just a warning, let iterate, the warning may disappear
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 28, 2013, 06:36
azt
allan thomson
azt is on a distinguished road
Extend your computational domain at the outlets, i.e. ensure that the outlet is far away from the tee
azt is offline   Reply With Quote
Old   June 28, 2013, 07:46
steven
Ok, thank you, i will wait a bit.
Old   June 28, 2013, 07:48
steven
Thank you. in this case the distance of outlets are at least 25 times that of diameter
Old   June 28, 2013, 07:54
steven
hello, Maxime,this is what i get. do you have some suggestions?
https://www.dropbox.com/s/30deqc29eq...ed%20flow.docx
Old   June 28, 2013, 08:44
-mAx-'s Avatar
Maxime Perelli
you have a convergence problem, and I don't think it comes to your reversed flow
-check Mesh
-how are your turbulent bc?
Old   June 28, 2013, 08:58
steven
-check Mesh
the mesh is not too bad. i chose the standard wall function. here are the informations https://www.dropbox.com/s/30deqc29eq...ed%20flow.docx
Old   June 28, 2013, 09:19
-mAx-'s Avatar
Maxime Perelli
-what is the quality of worst element? (show worst element option in gambit)
-what are the tubulent bc at your inlet (you showed the turbulent model)
-did you scaled your model?
-can you copy and paste the output from checkMesh
Old   June 28, 2013, 09:46
steven
hello, this is the information. thank you
https://www.dropbox.com/s/xml8ctvagskchbf/0628-2.docx
Mesh Quality:
Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality.
Minimum Orthogonal Quality = 2.75142e-01
Maximum Aspect Ratio = 1.61014e+01
Old   June 28, 2013, 09:50
-mAx-'s Avatar
Maxime Perelli
ok, your mesh is ok and seems to be scaled
in the velocity BC, you should have turbulent parameters, waht do you have?
How is you material? density, viscosity?
Old   June 28, 2013, 10:01
steven
i have the parameters of K and epsilon. k=0.053985 and epsilon=1.4722. the velocity is 5m/s, it is calculated with the Re=100000. the material is water-liquid. density is about 1000kg/m3, and viscosity is about 0.001kg/m-s
Old   June 28, 2013, 10:15
-mAx-'s Avatar
Maxime Perelli
Ok I have to hurry
Try to switch with realizable-kepsilon
Try with and without enhanced wall treatment
Old   June 28, 2013, 10:21
steven
sorry, i didn't understand what you mean 'realizable-kepsilon'. the k,epsilon values that i used are also calculated with Re=100000.
Old   June 28, 2013, 10:43
-mAx-'s Avatar
Maxime Perelli
Other turbulence model
Old   July 2, 2013, 03:33
steven
hello Max, i have tried the realizable k-epsilon, but the situation didn't change, there are still problem of conbergence and warnings of reversed flow. By the way, the Y+ is between 5 and 30.
Old   July 2, 2013, 05:12
rayan
rayan24 is on a distinguished road
I have same problem and I think it is the boundary conditions imposed on your two outputs which poses the problem .. when you have two output can not impose "pressure" at outlet..
What are your boundary conditions at the outlets??
rayan24 is offline   Reply With Quote
Old   July 2, 2013, 05:24
steven
Originally Posted by rayan24 View Post
I use outflow as the BC of outlet. in fact, i had wanted to try the pressure outlet, but i don't know the factors that i have to fill
Old   July 2, 2013, 08:20
rayan
The condition of pressure outlet is valid when we have "one outlet" for two and more of outlet this condition is not valid, you must use the "equal flow rate" at outlets.. try to reduce the underelaxation at the minimum (0.1 or 0.2)
Old   July 2, 2013, 08:23
steven
so what should I put as the gauge pressure?
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] NormalVector ANSYS 1 May 15, 2012 23:50
Reversed Flow for a tenth slice of a rotor neptunemmx FLUENT 10 January 30, 2012 13:51
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
