Reference values
Old   July 19, 2013, 07:12
Default Reference values
Vipin
vipingawande is on a distinguished road
Dear sir
I am calculating Average Nusselt Number in Fluent....
I am changing the reference value .....
what is the effect of reference value on solution?
How to set it with reference to a problem?
I am simulating 2D rectangular duct with Heat flux is given at middle of duct
inlet temp= 300 k
i am changing reference temp to some other values.....
help me.....
vipingawande is offline   Reply With Quote
Old   July 20, 2013, 12:46
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The reference values in Fluent do not affect the solution. They are used for the calculation of dimensionless numbers.
flotus1 is offline   Reply With Quote
Old   July 20, 2013, 13:00
Vipin
If I changed reference temp to get the required Nusselt Number ...is it a valid solution.
How to set reference temp for Nu no.?
Old   July 22, 2013, 04:20
flotus1's Avatar
Alex
The reference values are those you would take if you calculated dimensionless numbers yourself.
You would not take 5m as a reference length to calculate the Reynolds number if the characteristic length of your flow setup was 1m.
I know nothing about your heat transfer setup, but I guess the correct reference value for the temperature is the free stream temperature at the inlet.
Or, since you obviously want to compare the results to another source, you should take the same temperature as in the reference work you are comparing to.
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 06:54
Reference Values Lilly FLUENT 1 May 31, 2012 09:51
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
