Problem in discretising the governing equation.
Old   September 3, 2013, 11:19
Question Problem in discretising the governing equation.
Sahil Kala
sahilkala50 is on a distinguished road
Hello all,
I am new to CFD coding and have started with a relatively simple problem statement of "Incompressible flow of a viscous fluid through a pipe". But this simple problem too seems to be turning difficult for me. I have problems in the following areas-
1. I am not able to decide the discretisation scheme to be used for the space discretisation and for discretising the equation.
2. I am referring the book "Computational Fluid Dynamics by J. Blazek" but even after reading it i am not able to formulate a good algorithm for solving the problem.
3. It would be very helpful for me if you can tell me the guidelines one must follow before starting to write the code or create the algo for a particular problem.
Thank you in advance. :-)
sahilkala50 is offline   Reply With Quote
Old   September 4, 2013, 03:30
michujo is on a distinguished road
Hi. This is just my opinion but I'd have a look at the book by Versteeg & Malalasekera.
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   September 4, 2013, 05:45
duri
duri is on a distinguished road
Originally Posted by sahilkala50 View Post
Hello all,
Blazek doen't explain pressure based algorithms which is suitable for incompressible flow. There are pressure based algorithms available such as SIMPLE, PISO etc for incompressible flows. Refer patankar's book.
duri is offline   Reply With Quote
coding skills.., discretisation, equations, incompressible flows
problem about adding another equation of state yhaomin2007 OpenFOAM 4 May 16, 2012 04:36
Problem with a leapfrog scheme for wave equation Shiranui Main CFD Forum 0 June 22, 2010 09:19
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
governing equation of sliding mesh torn FLUENT 1 August 10, 2006 03:34
Energy equation convergence problem Reza Main CFD Forum 0 August 27, 2003 13:09
