TRANSIENT SOLUTION CONVERGE
Old   October 30, 2006, 08:16
Default TRANSIENT SOLUTION CONVERGE
MARK
I will ask a simple question related transiet analysis. How can I understand a transiet solution is converged or not? Thanks already for your replies.
Old   October 30, 2006, 23:25
Default Re: TRANSIENT SOLUTION CONVERGE
ganesh
Dear Mark,
A "transient solution" does not "converge" in the same sense as a "steady-state" soltuion. To terminate a transient problem, you would need to look at the response of suitable integrated coeffcients(eg. Cl or Cm for an airfoil) with time, and if they have achieved a periodicity with nearly constant amplitude then transient response is considered to be "converged"
Hope this helps
Regards,
Ganesh
Old   October 31, 2006, 01:04
m.suresh kumar
In the software CFDesign, we will see the last ten to twenty iterations in the convergence monitor. If the same pattern has been repeating and values are more or less similar, we will judge as converged.
Old   November 2, 2006, 10:08
Mani
ganesh, that's useful only if there is a periodic solution.
I always thought the usage of the term "transient" is arbitrary. The real question is "how do I know that an unsteady solution is converged?", and the answer is: by observing convergence within each time step (in a dual-time approach) and by performing a temporal resolution study (decrease the time step and see if the solution changes significantly).
what should I do if the solution didn't converge? Beeny FLUENT 6 August 27, 2011 00:04
Best practice for transient simulations? siw CFX 5 October 30, 2010 05:45
simple algorithm, converge of solution bbasal Main CFD Forum 0 February 13, 2010 02:58
Problem with transient solution of flow past a row of cylinders jostanek Main CFD Forum 0 January 6, 2010 12:16
Solution Does Not Converge Rif Main CFD Forum 3 March 7, 2008 05:33
