October 4, 2013, 06:09 |
using time as a variable to classify a pde
nargess
Rep Power: 12 |
Hello Dear friends
I have a problem with classifying PDEs which is I don't know when to use 'time' as a variable for classifying the equations! I would be grateful if I can find the answer of my question as soon as possible. thanks alot |
October 4, 2013, 08:10 |
Filippo Maria Denaro
Rep Power: 71 |
the time variable appears for parabolic, hyperbolic equations. Just consider a standard classification method for a PDE in terms of x1, x2, ...xn independent variables and assume x1=t.
October 4, 2013, 10:24 |
is there anyone?
nargess
Rep Power: 12 |
Isn't there anyone who can help me about the so-called problem?
October 4, 2013, 10:43 |
Rep Power: 71 |
October 4, 2013, 12:15 |
nargess
Rep Power: 12 |
Thanks for your reply. I have studied Hoffman's CFD book, sometimes it uses only the coefficient matrix of d/dx to define the type of equation and somewhere else it uses the coefficient of time derivative either. for example in equation du/dt+a du/dx=0 , should i use time coefficient to determine the equation type?
October 4, 2013, 12:42 |
#6 | |
Rep Power: 71 |
Classification is done for PDE of the type: a(x1,...xn,f,..)*d2f/dx1^2 + ..... = 0 For example in a 2D case the PDE a* d2f/dx1^2 + b * d2f/dx1dx2 + c*d2f/dx2^2 =0 can be classified by analysing the characteristic curves. That can be found in many textbook. If am right, you can see the Hirsch book that uses the eigenvectors analysis |
October 4, 2013, 14:11 |
nargess
Rep Power: 12 |
thank you so much, I will read the book.
October 6, 2013, 05:11 |
another problem
nargess
Rep Power: 12 |
here is what I got :if 'time' derivative is of the highest order in a equation I have to use it's coefficients in chlassifying the equation or sytem of equation. am I right? for example in the following system
du/dt+a du/dx+b dv/dx=0 dv/dt+c du/dx+ d du/dx=0 but there is another question here: if we have a system like this:. du/dt+a du/dx+b dv/dy=0 dv/dt+c du/dx+ d du/dy=0 here we have 3 variables but as I studied in different books we just use d/dx and d/dy coefficient matrixes to classify the equation. |
October 6, 2013, 05:25 |
#9 | |
Rep Power: 71 |
You can use a matrix form of the system to write du/dt + A. du/dx+B. du/dy = 0 use u= uk*exp(i k.x) and develep an aigenvalue analysis |
October 6, 2013, 05:38 |
nargess
Rep Power: 12 |
thank you so much.
classifying, time |
How to determine time step size and Max. iterations per time step. | pratik c | FLUENT | 46 | January 21, 2024 12:21 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
