October 21, 2013, 05:49 |
Outflow vs Convective BC
SM
Rep Power: 15 |
I am having troubles with LES of jet flow of Re~22000 using FVM incompressible 2nd order code. In the streamwise direction at outlet I use outflow BC i.e. set velocity gradients to zero. I found same case simulated earlier with outlet placed at 20D. But in my case if I keep outlet 20D the run blows up few iterations after the flow reaches the outlet plane. I observed the same with 30D and now I am running with domain of 45D. The difference with literature is that they are using convective BC as common with compressible solver. My question is can the outlet BC have such a effect? If not what can be other reason? Thanks SM |
October 21, 2013, 15:04 |
Rep Power: 13 |
Outflow boundary condition restricts your velocity components and the basic assumption for applying an outflow bc is that the flow must be fully developed at the outlet in question.
During LES, the outflw is not fully developed, hence we can't use outflow bc. Convective bcs have no as such physical significance, they are used for unsteady flows for being numerically stable for unsteady flows. Many papers from CTR stanford use convective bc at outflow for the above said reason. |
October 21, 2013, 15:17 |
Filippo Maria Denaro
Rep Power: 71 |
I suggest a check for the pressure equation. It is the divergence-free constraint really ensured cell-by-cell at the outflow?
October 22, 2013, 08:07 |
#4 | |
SM
Rep Power: 15 |
Also the codes from CTR are compressible mostly so that necessitates convective BC? |
October 22, 2013, 08:09 |
#5 | |
SM
Rep Power: 15 |
There is a stretching of the Cartesian grid. Can aspect ratio be a issue? |
October 23, 2013, 00:57 |
#6 | |
Rep Power: 13 |
2. CTR's papers on incompressible flows also use convective BC, so its not only the compressible flows that have it. Even if you see the works from Aero dept. from IISc and IIT-K, they also extensively use convective BC for unsteady, transient and developing flows. |
Outflow boundary Control Volume SIMPLE Help !!! | Mizerable | Main CFD Forum | 4 | August 22, 2011 13:00 |
Sponge layer for outflow BC | irc | OpenFOAM Running, Solving & CFD | 13 | April 8, 2009 04:18 |
convective boundary condition for outflow BC | Pang Shengyong | Main CFD Forum | 1 | August 24, 2007 17:21 |
Convective outflow boundary condition. | T. Gra. | Main CFD Forum | 0 | June 26, 2003 12:56 |
Outflow Bocos | Romuald Skoda | Main CFD Forum | 3 | August 6, 1999 03:08 |
