CFD Analysis of Model Aircraft
Old   December 1, 2008, 22:49
Default CFD Analysis of Model Aircraft
Sashankh
I am in need of a tutorial on the meshing and analysis(3D) of an entire aircraft using Gambit and Fluent. I have created a CAD model. Any help would be really appreciated.
Thanks!
Sashankh
Old   December 2, 2008, 00:35
Default Re: CFD Analysis of Model Aircraft
Ahmed
http://geuz.org/gmsh/gallery/a319_4.png
http://geuz.org/gmsh/gallery/a319_2.png
You need to import your geometry into Gambit. create a volume around the imported geometry, subtract your geometry from the volume, because of the symmetry of the flow field you need half that, use a plane to clip it, mesh, assigne your boundary conditions and start your run. Good Luck
Old   December 2, 2008, 00:58
Sashankh
I have created and subtracted the volume in GAMBIT. I've done this for half the wing at present. I plan to do this for the entire aircraft after this. But i'm getting an error during meshing abt skewness and i'm not able to sort it out. Any advice?
Thanks!
Old   December 2, 2008, 18:31
Ahmed
change mesh density (number and distribution) until you are happy with the mesh, important to remember "No negative volume" it is unrealistic to advice on details without having a complete picture of what you are doing and what are your objectives from this simulation, for instance how big is your domain compared to the plane size, how many skewed cells compared to the total number of cells, is it subsonic or supersonic flow simulation, etc..............Good Luck
Old   December 2, 2008, 20:33
Sashankh
Thanks for your reply. Here are soem details for the analysis of a half wing: Wing chord: 500mm Wing span(half span):1250mm Enclosure volume(brick volume): 6000*4000*5000 mm It is subsonic flow.
I have tried various mesh densities but to no avail. My aim is to visualize the flow over this wing and then insert wingtips and check the difference. If you have any advice it would be really helpful.
Also, any idea what the function "ignore size mesh" in Gambit will do when toggled on?
Thanks!
Old   December 8, 2008, 20:12
Wifi Lee
Yes,I can help you in gridding your model!
Old   December 17, 2008, 22:31
siddiq
Hi..i want a tutorial on meshing of a complete model aircraft,if anybody can help me in this regard...
Old   January 16, 2009, 04:24
sam
In Gambit?
Old   November 22, 2013, 14:02
Question
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Originally Posted by Ahmed
;58054
I saw your pictures of mesh. I always thought structured mesh can work much much better for this kind of case. And the generation of the structured mesh for this case is not very difficult. I'm wondering has anyone ever tested the accuracy of the unstructured mesh for this kind of case comparing with the structured mesh? Any experience on that?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
CFD Analysis of Transport Aircraft Amit Main CFD Forum 1 July 1, 2008 05:36
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 12:58
