Radiative heat transfer
Old   August 4, 2004, 06:49
Default Radiative heat transfer
Anton Lyaskin
Hi!
I'm working at the re-entry problems now, using simple engineering formulas to estimate heat fluxes. I would like to account for radiation from the shock wave. So I wonder, can we treat shock wave as radiative surface, assuming that heat flux from it is
q=emissivity*Boltzman_constant*T^4 ?
And if yes, then what is the estimation for emissivity of hot ionized gas?
Old   November 25, 2013, 08:49
Post
Amir
gomnam15010 is on a distinguished road
Hi
which simple engineering formulas used to estimate heat fluxesin reentry capsule? did you used Detra, Kump & Riddel formula?
gomnam15010 is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Radiative Heat Transfer kamakura117 STAR-CCM+ 0 July 19, 2010 19:51
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
radiative heat transfer Tim FLUENT 0 February 20, 2004 13:28
