Pressure Spikes????
Old   January 23, 2007, 04:22
Default Pressure Spikes????
Mubassh
Hello Friends,
I would like to know a mathematical and/or physical reasons for "pressure spikes" occuring in CFD simulations. I have one simulation case which exhibits this nice pressure spikes behavior(got oppor to learn the reason []).
Let us consider a case with moving boundary zone(cylinder with valve). I am imposing jerking motion BC to the valve. velocity is constant for every two simulation timestep(0-1-2s=> 3m/s, 2-3-4=>5m/s, 4-5-6=>2.5m/s ...). This BC gives me pressure spikes. I have tested many cases with jerking motion and successfully got Pressure Spikes.
Would you explain (or) give me a pointer about P-S cause?. I will be very thankful for this help.
Regards,
Mubassh
Old   January 24, 2007, 10:59
Default Re: Pressure Spikes????
Renato.
Take a look at this
http://dissertations.ub.rug.nl/FILES...eefsman/c2.pdf
on page 76 there's a possible explanation to your question.
Regards
Renato.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Using pressure outlet BC Shreyansh FLUENT 0 November 5, 2010 14:57
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
