March 21, 2007, 22:09 |
Convergence based on Reynolds Number
The paper "Accurate Three Dimensional Lid-Driven cavity flow" J.comp.Phy 206(2005) 536-558 by Albensoeder & Kuhlmann, defines in Page 543, a Convergence criteria for steady flow as : max( u(X,t) - u(X,t-dt) ) / dt*Re < epsilon, X is a vector here. My question is : Why is Reynolds number appearing here ? Regs, Dominic |
March 22, 2007, 07:32 |
Re: Convergence based on Reynolds Number
Is the Re number at numerator or denominator:
1) ( max ( u(X,t) - u(X,t-dt) ) / dt ) * Re or 2) max ( u(X,t) - u(X,t-dt) ) / ( dt * Re ) ? |
March 22, 2007, 10:27 |
In the Denominator
March 22, 2007, 08:06 |
Put in the definition of the Reynolds number in terms of the reference velocity and other things, and you will see that the criterion says that the incremental velocity in a time step needs to be small compared to the reference velocity. How small depends on the other things. This is to make the criterion independent of the velocity scale.
March 22, 2007, 10:35 |
Thanks, If we put in the dimensions of each quantity, i see that, the entire term goes as x/t^2 < epsilon ... where x, t are length and time scales respectively. Something like an acceleration ??
March 22, 2007, 12:24 |
= max (u(X,t) - u(X,t-dt))/dt * (1/Re ) = acc * (1/Re) 'acc' represents the temporal acceleration, determined between two successive temporal-stations (time-snapshots) for a slowly-evolving solution. This term should go to zero as a steady solution is approached - if it exists. I'm wondering why they multiply 'acc' by (1/Re)? desA |
Two way particle coupling in OF 2.0 and the particle reynolds number | preichl | OpenFOAM | 7 | February 9, 2012 15:38 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Changing Reynolds Number | pvt | FLUENT | 0 | June 7, 2009 00:11 |
Reynolds Number Again | Ogbeni | CFX | 2 | June 2, 2005 23:34 |
High Reynolds Number Incompressible Flow | Nick Lavery | Main CFD Forum | 3 | February 19, 2002 15:47 |
