Convergence for inviscid flow over sylinder
Old   March 21, 2007, 05:59
Default Convergence for inviscid flow over sylinder
Rjakk
I have a sylinder which I send an incompressible, inviscid flow over. All walls and sylinder is set to SLIP-condition. First I want to send water over the sylinder with, for instance, 10 m/s, and afterwards increase this to 10.5, and compare the total kinetic energy of the two control-volumes.
But flow over a sylinder isn't steady, is it? I've got great problems with convergence using steady flow. The most important thing is that I compare the two cases for flow at the exact same moment. Can I run a transient analysis for this? Or is there a good way to get convergence using steady flow?
The reason for me wanting to do this, is that I want to find the "added-mass" of my object. Optimally I would want an irrotational flow (potential), but I guess this is not possible with my CFD package (Cd-Adapco Star-CD.)
Thanks in advance.
Old   March 21, 2007, 08:24
Default Re: Convergence for inviscid flow over sylinder
Mani
Incompressible, inviscid, rotational (Euler) flow over a cylinder is problematic. There may be a steady solution, but it would be very difficult to obtain numerically for this reason: You cannot avoid numerical dissipation. Numerical dissipation will act somewhat (in a very uncontrolled and arbitrary way) as if you had a small non-zero viscosity. This will result in an effective Reynolds number which may be very large (also depending on free stream velocity and cylinder size). Large Reynolds number means: No steady solution! Small numerical dissipation will really spoil it for you. There could be two ways out of this dilemna: a) make sure you choose a small velocity over a large cylinder diameter, b) increase your artificial dissipation to get a lower effective Reynolds number (this will have a damping effect on the instability). Either way it's going to be an "engineered" solution that depends a lot on numerical dissipation.
Here is what you really should do: Run a potential flow code or apply the well-known potential solution analytically.
Old   March 21, 2007, 10:53
Ahmed
When selecting your viscous model in your code, select the inviscous model (commercial codes have this option). If the code you are using does not have that option, you can always select a viscous model and entering a value of Zero for the viscosity coefficient
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
mass flow convergence on interfaces Tatiana STAR-CCM+ 0 June 25, 2009 03:19
Convergence for axisymmetric flow bl201 Main CFD Forum 5 August 16, 2005 17:01
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 03:24
