re: Volumetric Heating
Old   April 13, 2007, 11:46
Default re: Volumetric Heating
Wooster
I have a problem with CFX 11.0. I'm trying to figure out various ways of applying volumetric heating. My problem:
I have a beam of ions hitting water, and causing heating (Brag peaking, etc.). MCNPX made some text files relating radius and depth to the amount of heat generated in the water. So now I have Q_dot(R,Z).
My model is in cylindrical coordinates, but when I go to import the data file (user function), I can either have one dimensional or 3 dimensional and the 3 dimensional is in x,y,z which poses a problem (since its a function of 2 variables). How should I go about taking this data and revolving it around the axis? My next test will try and put the data in an expression form. Thanks in advance!
Old   April 18, 2007, 12:41
Default Re: re: Volumetric Heating
Wooster
Problem solved. A little elbow grease and some sleepless nights created a massive text file across varied theta angles which imports easily into CFX....
Now if only I could graph that particular function in CFX...
-M
Old   April 18, 2007, 13:46
opaque
Dear Wooster,
You are asking in the wrong Forum.. It may take longer to get a response from CFX-only readers.
In anycase, create an Algebraic Additional Variable and make it equal to your interpolation function.. You will see it in CFX-Post..
Insert Additional Variable, select Undefined.
Goto your Domain, and under Fluid Models/Solid Models activate your additional variable for this domain. Set it equal to your function.. Done..
Opaque.
Old   April 19, 2007, 15:43
Wooster
Thanks Opaque, I've implemented your suggestion. also, I put a similar question to the CFX only forums as this one was obviously filed wrong (on my part).
Induction heating of hollow cylinder cfd.geek FLUENT 1 August 12, 2022 16:38
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 08:14
Pressure variation in a heating channel gRomK13 Main CFD Forum 0 August 6, 2009 12:18
Lower heating value Andrea Siemens 2 July 30, 2007 07:19
