On Acoustics with RANS for Low-Mach number flow |
April 17, 2014, 21:43 |
Rep Power: 13 |
I am asked to do acoustic analysis with RANS model for my thesis. I am using inhouse k-omega sst model applied in overture. Since my flowfield is with very low mach number (vel=10, M=0.05) I am not sure whether there's any point on calculating spectra of SPL. Can anyone please guide me regarding this? I am attaching my instantaneous acoustic pressure contour here for oscillating S809 airfoil. Please let me know if someone has any tips for this
Best wishes, Somdeb Bandopadhyay |
April 18, 2014, 03:31 |
Filippo Maria Denaro
Rep Power: 71 |
well, that sounds strange...using RANS for solving acoustic problem what kind of information you want to extract??
April 18, 2014, 04:00 |
Rep Power: 13 |
Hi again,
As per theory phi_comp=phi_incomp+Phi_acoustic where Phi=fluid property When using RANS, I am assuming that I am getting the mean (time avg) value of phi So by I concluded that Phi_acoustics==Phi_comp-Phi_incomp I know it is not very accurate, but that's what I can do at max after being asked to add "acoustics result" before 1 month of my first presentation. Am I wrong on my assumptions? I compared my instantaneous acoustic pressure for naca0012 with C. Tam's JFM paper of 2012.It was "similar". So I am planning to just capture the instantaneous acoustic pressure contour (roughly..since it's impossible for me to write LES now) and leave it at that (I intend to target my solver description & overset grid as main "topic")
Best wishes, Somdeb Bandopadhyay Last edited by som87; April 18, 2014 at 05:08. |
April 18, 2014, 04:09 |
tb_cfd
Rep Power: 12 |
Acoustics is depending on instationary effects (fluctuations). You can use your solution of the RANS-simulation as start solution for a transient CFD. Then it is possible to extract the fluctuations and you can calculate for example the acoustic spectra with FW-H analogy.
April 18, 2014, 04:13 |
Rep Power: 13 |
I dont want to use FW-H.
Reason is:- My airfoil is oscillating, so obviously the acoustic wave generating points at boundary layer will change position. So my mono/di/quadrapole's positions are NOT fixed over airfoil span
April 18, 2014, 05:16 |
Rep Power: 71 |
well, therefore you should use URANS, isn't? I think that after solving the flow field you should resolve the acoustic field assuming to know the velocity field
April 18, 2014, 05:23 |
Rep Power: 13 |
I am using URANS sir, and I just wanted some senior's comment on my approach, that's all.
What I am doing is:- Running two separate simulations with URANS in compressible & incompressible model. After 20 cycles (of airfoil oscillation) on each I am capturing the data. I did not intend to do acoustics at start (since URANS wouldn't be by choice if I wanted to), but now I HAVE to add some acoustics result.
February 23, 2016, 00:51 |
Dear Somdeb,
Although this is not relating to your issue of URANS. I am writing here because I emailed you on your gmail account for a paper issue. The paper you wrote on DES study over a transonic body. Could you please reply to me on that? Regards, |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Turbulent flow at low Mach number | robyTKD | SU2 | 5 | January 3, 2014 03:18 |
Boundary conditions low Mach number flow | lost.identity | Main CFD Forum | 0 | November 28, 2010 04:44 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 16:16 |
