Catalytic Combustion problems
Old   August 28, 2009, 05:46
Default Catalytic Combustion problems
Gerhard Selle
yellow-stuff is on a distinguished road
hello everybody,
I am trying to simulate the catalytic combustion of propane in a channel. The wall surface of the channel is coated with Platinum.
I have written an UDF to describe the wall surface reaction rate and hooked it up to Fluent. The reaction takes place, but my temperature increases with every iteration above 5000K, which is way too high.
If I increase the heat loss through the outer wall to absurd values (150w/m2-k) the temperature decreases.
What can be the problem of the increasing temperature?
I am using the pressure based solver and transport+reaction species model with wall surface reactions, inlet diffusion, thermal diffusion and heat of surface reactions enabled. The specific heat of the species is calculated via a piecewise-polynomial function, of propane/air mixture via mixing law.
Thanks and regards
ps. This is my first time I deal with Fluent.
yellow-stuff is offline   Reply With Quote
Old   September 3, 2009, 01:02
Gerhard Selle
Well, I created a new mesh and the problem of the increasing temperature doesn't occur anymore.
But now I have some convergence problems with my setup. There are in the majority of cases fluctuations in the residuals of continuity and I don't think I have convergence because there is no flattening of the monitored variables.
Mass flow rate at the outlet and maximum values of temperature on wall and symmetry are monitored.
What can I do to get convergence and improve my solution?
Any recommendations?
Thanks a lot.
Regards
Old   May 1, 2014, 17:47
Kostis Chatzi
kostis217 is on a distinguished road
hi ,
yellow-stuff i am experiencing the same problem with you but i am currently working with methane catalytic combustion on Pt. have you found a solution to your problem? if you do, may you help me. thanks a lot in advance
kostis217 is offline   Reply With Quote
Catalytic combustion CPRL Siemens 4 May 1, 2014 17:49
Problems in combustion of char Cleiton CFX 2 December 12, 2008 11:35
Dimensionless Problems Combustion Pedro Pacheco Main CFD Forum 1 September 17, 2007 16:05
IC engine Spray-EBU combustion model problems deisler Siemens 0 May 14, 2007 05:45
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
