Automatic gridding in CFX
Old   October 19, 1999, 07:50
Default Automatic gridding in CFX
Oliver Breitfeld
Does anybody know how to use CFX tools such as Meshbuild, Meshimport to generate a mesh from a log-file etc. without opening the interactive part of the program (this of course applies only to Meshbuild), or can I create a mesh within curved boundaries in the userroutines (including GP)
Regards Oliver
Old   October 19, 1999, 20:00
Default Re: Automatic gridding in CFX
Hi Oliver,
You can run Meshbuild and Meshimport from the command line using "runmb" and "runmi". There is an option to load in a configuration file into Meshimport from the command line - see p106 of the CFX 4.2 Environment manual.
If you are using CFX-Build to generate your geometry you can run it in batch mode (ie no GUI) using the "-b" option and specifying a session file to play. Refer to the same page of the manual for this.
Alternatively, you can not use the pre-processors at all. If you have a very simple geometry you can specify it using the >>MODEL TOPOLOGY, and >>CREATE GRID commands in the command file. More complicated grids can be specified using the user fortran routines USRGRD and USRTPL.
Cheers, Glenn Horrocks
Old   October 22, 1999, 03:39
Oliver Breitfeld
Hi Glenn,
Thanks for your responce. I would love to use Meshbuild to create a geometry file from a log-file which is 'altered' externally. I cannot see how to obtain a geometry file from a log file just by using command line options without pressing any buttons, just like in CFX-build. Could you point me in a direction how to achieve this?
Regards Oliver
Old   October 24, 1999, 20:03
Hi Oliver,
I don't think Meshbuild has an equivalent of the batch mode in CFX-Build. Try opening a log file in a text editor and seeing if you can work out the format - that will minimise the clicking you have to do in Meshbuild.
Cheers, Glenn
Old   October 25, 1999, 07:28
O. Breitfeld
Hello Glenn,
My problem is that I don't want to have any clicking at all. Well, I suppose I have to use BUILD.
Thanks and Regards Oliver
Automatic wall treatment in CFX Chander CFX 13 May 6, 2017 00:45
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
