LateX style file
Old   October 24, 1999, 11:03
Default LateX style file
Kuttoosan
Hi .. Can anybody help me in getting a LateX style file for making a technical paper on CFD.
advance thanks
Old   October 25, 1999, 09:03
Default Re: LateX style file
Patrick Godon
You can use Tex and LaTeX as they are to make a paper. There is no problem to write the Navier-Stokes equations and all the rest. Actually some of the style files are defined by the user. If you need to put postrscript figures in the text of the paper, then only you might need some additional sty files. But you would also need to have an example to see how it works and how it is defined. But when you submit your paper to a Journal, you actually need to put the figures at then end, in a larger format, and this can be done without a sty file.
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
