discontinunous galerkin method
Like Tree1Likes
  • 1 Post By Praveen. C
Old   July 28, 2007, 21:56
Default discontinunous galerkin method
jack
hi guys who can tell me the advantage of Discontinunous galerkin method, has anyone already used this method in hypersonic flow?
Old   July 29, 2007, 00:55
Default Re: discontinunous galerkin method
jinwon
It was good for handling of shock because it contains the characters of FVM as well as those of FEM. It's pretty close to the FVM in some sensors.
Old   July 29, 2007, 14:02
Praveen. C
Some nice things I can remember about DGFEM, randomly listed.
High order schemes are easy to construct in a systematic way.
Order or accuracy can be varied from element to element (p-refinement)
Easier to use for hybrid approaches like RANS-LES since model can be varied from element to element.
hp-refinement is possible leading to use of optimal grid sizes
Very small stencil, each elements has to communicate with its immediately adjacent elements only. Good for parallellization. Simple communication pattern.
Fixed stencil irrespective of order of accuracy
Finite volume comes out as a low order version of DGFEM
Complex geometry - unstructured grids can be used
Discontinuous shape functions
* Upwind fl‚ux formulae can be used
* Conservative on each element
* Shock capturing scheme
* Any type(s) of element
* Hanging nodes OK - Cartesian grids
Block-diagonal mass matrix - decoupled between elements
No mass lumping required
Simple communication pattern: Good parallelizability
Quasar_89 likes this.
Code for Discontinuous Galerkin Method ? Ameya J Main CFD Forum 2 April 21, 2011 05:45
Navier stokes and the standard Galerkin method micheldup Main CFD Forum 0 March 1, 2011 09:24
Weak statement for Galerkin Method rugabug Main CFD Forum 0 March 26, 2010 19:19
Galerkin Method Applicable for Finite-Volume? Scott Main CFD Forum 0 September 7, 2008 19:02
Discontinuous Galerkin finite element method Tony Main CFD Forum 0 May 27, 2003 18:48
