2D Godunov Fluxes
Old   July 10, 2014, 05:24
Default 2D Godunov Fluxes
Aniket Sachdeva
thegodfather is on a distinguished road
I am writing a code for solving the 2D Riemann problem (the 4 quarter problem) using Godunov's Method. When determining fluxes in x direction (F) a local riemann problem is solved at each cell face which will give values of pressure, density and x velocity only. But the flux vector also contains y velocity term, which is not supplied by the solution to the local riemann problem. What is the procedure to determine y velocity at x cell faces?
thegodfather is offline   Reply With Quote
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 15:00
CANTERA code to get pure species mass fluxes gemmafebrer Main CFD Forum 0 October 19, 2010 11:42
Viscous fluxes in a Riemann HLLC solver Bryce Sharman Main CFD Forum 5 July 8, 2009 23:29
Fluxes of scalars at wall faces K Sanjay Phoenics 10 August 15, 2005 10:45
Roe upwind fluxes!! Magesh Main CFD Forum 2 July 17, 2003 11:35
