flow over cylinder
Old   August 11, 2007, 03:54
Default flow over cylinder
joe
i've gone through many tutorial in the internet but still cannot mesh succesfully and use fluent to anaylze the cylinder. can anyone give me a step by step guide from making vertices to analysing it in fluent. the radius is 30.15mm. thank you
Old   August 11, 2007, 06:03
Default Re: flow over cylinder
Lionel S.
It depends on the Re number, At Re>100, you will probably observe the Von Karman street, which is a non stationary phenomena. So you should perform an unsteady simulation. But the Von Karman street is something difficult to simulate.
At lower Re number (say less than 50) the flow will probably be steady.
You can try a laminar approach with Fluent, but I'm affraid it may not converge. So a standard k-epsilon turbulence model could be used for initial trial.
For other details, it should be standard Fluent use.
Hope it helps.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 02:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 13:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
