Is cosmosfloworks any good?
Old   August 12, 2007, 08:37
Default Is cosmosfloworks any good?
chris
Does anyone have any knowledge or experiance of cosmosfloworks (add-on cfd code to Solidworks). I have a limited budget and need to know if this is worth purchasing. My intent is to use it for fluid mixing calculations. I am not happy asking the supplier if its any good as I know what his answer will be already.
any help will be much appreciated.
Old   August 12, 2007, 11:48
Default Re: Is cosmosfloworks any good?
Harry
Not really is the honest answer, I have used it a bit and it wasn't that great. Better if you can get one of the "bigger" commercial codes, they have cheaper cut down versions - flow wizard, star-works etc
Old   August 12, 2007, 14:53
Peter Specht
I agree 100 % with Harry. I tested it for 1 year and it was waste of time. No correct results in pressure drop (no correct modeling of wall function) Now i use fluent and I am happy. you can also rent fluent for 1 day, 1 week, etc. When your results should be correct you should take one of the 3 big ones. Or you have a look at http://www.opencfd.co.uk/index.html But i do not know anything about it. It seems to be nice.
Regards Achim
How to do a good geometry clean-up in GAMBIT mahadevan.swamy Main CFD Forum 0 June 19, 2009 21:13
Good convergence but without a good heat balance Juan Martin Catelén CFX 4 June 27, 2007 18:41
[blockMesh] Is blockMesh generally considered a good quality tool york OpenFOAM Meshing & Mesh Conversion 4 November 15, 2006 13:42
A good question about UDS Z FLUENT 1 March 31, 2005 15:14
engine simulation CFD: what's a good book? Geoff Main CFD Forum 0 August 23, 2001 10:04
