Non-dimansionalization of NS-eqns with gravitity
Old   August 25, 2007, 07:49
Default Non-dimansionalization of NS-eqns with gravitity
chandra
I have a very simple question: If gravity is there in, say, y-component of the NS-equation, can I solve its non-dimensional form and port it to other similar problems?!
DEL_v over DEL_t + u.DEL_v/DEL_x + v.DEL_v/DEL_y = -(1/rho).DEL_P/DEL_y + nu.(DEL^2 v) - g : Dimensional Form
DEL_v* over DEL_t* + u*.DEL_v*/DEL_x* + v*.DEL_v*/DEL_y* = -DEL_P*/DEL_y* + (1/Re).(DEL^2 v*) - (L/V0^2)g : NON-dimensional Form
As we can see in the 2nd equation,it contains "Re" as well as (L/v0^2). If "Re" and (L/v0^2), BOTH are same for any two similar problems, only then solution of this non-dimensional equations seems to be useful?!!
Could any of you please confirm it?
Thank you,
-Chandra
Old   August 27, 2007, 07:42
Default Re: Non-dimansionalization of NS-eqns with graviti
Jake
The second similarity parameter you found is the reciprocal of the Froude number squared: Fr = V0/sqrt(gL).
Dynamic similarity is achieved if you match Re and Fr.
Old   August 29, 2007, 04:18
p
if there are two geometrically similar systems with similar boundary conditions (non-dimensional) at the same geometrical correspondence, the two systems will have the same non-dimensional quantities like Re, Fr, u*, v*, delp*/dely* etc. hence if the equations are solved in non-dimensional form, the specific advantage is that irrespective of the properties etc of the fluids in the two apparently different systems (dimensional form), velocity, pressure etc profiles (non-dim) will be same. this helps in validating results when say experimental results are available for different fluids and/or different flow conditions. this also helps in scale up.
Old   August 29, 2007, 11:35
chandra
Thank you very much to both of you. It helped me a lot to have understanding of it.
Thank you,
-Chandra
Confusion about non-dimensionalization of NS eqns quarkz Main CFD Forum 2 November 18, 2010 08:21
How to model the NR eqns in a domain with empty space Vasilis Main CFD Forum 1 April 14, 2009 04:35
Need help to solve N-S eqns with F.V.M vasilis Main CFD Forum 4 October 7, 2008 02:56
Help to solve 2 eqns simultaneously in MPI Zonexo Main CFD Forum 2 June 1, 2008 20:21
Source term in NS eqns zonexo Main CFD Forum 5 February 3, 2006 17:33
