about nodimensition of two ideal enstropic eqation
Old   August 30, 2007, 11:49
Default about nodimensition of two ideal enstropic eqation
Stu. NO0523
Hi, I am using CFD method to calculate a nozzel internal performance,there are two equations: ideal mass-flow rate (1) W_i=sqrt(gamma/R)*(2/(gamma+1))**((gamma+1)/2/(gamma-1))*At*P_tj/sqrt(T_tj) ideal enstropic thrust(2) F_i=sqrt(2*gamma*R/(gamma-1))*W_p*sqrt(T_tj)*sqrt(1-(1/NPR)**((gamma-1)/gamma)) (John R. Carlson A Nozzel Internal Performance Prediction method, NASA TP3221,1992) after nodimension,reading: W_i=gamma*(2./(gamma+1))**((gamma+1)/(gamma-1)/2.)*at*p_tj/ sqrt(t_tj)/mach_inf (3) F_i=2*w_i/mach_inf*sqrt(2.*T_tj/(gamma-1))*sqrt((1.-(1./p_tj)**((gamma-1)/gamma))) (4)
(W_i~~rho_inf*V_inf,F_i~~0.5*rho_inf*V_inf**2)
I use eq.(3),(4) to get discharge coefficent C_d = W_p/W_i and thrust ratio coefficent C_f=F_r/Fi. for a nozzel the calculating C_d=74%,C_f=45%,all much smaller than the experiment, are eq.(3)&(4) wrong?but I have checked them again and again, I can't find problem, would anyone like to give me some advice?
Error: Pressure-far-field bc can only be used with ideal gases ldavis FLUENT 1 September 3, 2010 00:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
allways problems with ideal gas Ralf Schmidt FLUENT 1 March 31, 2006 10:35
Problem using ideal gas mark FLUENT 3 November 29, 2004 16:40
numerical vs. ideal solutions Gotfred Berntsen Main CFD Forum 2 September 22, 1999 05:48
