September 14, 2007, 01:19 |
nozzle boundary condition
I am solving the 1-D Euler equation using upwind methods for flow through a divergent nozzle. Three cases were tested:subsonic flow, supersonic flow and flow with shock. The subsonic inlet boundary condition produced incorrect result for the subsonic flow. B.C. & Density & Velocity & Pressure | Subsonic inlet & Fixed? & Float? & Fixed | Supersonic inlet & Fixed & Fixed & Fixed | Subsonic outlet & Float & Float & Fixed | Supersonic outlet & Float & Float & Float | Can anyone please advise me on this? Thanks, Shuo |
September 22, 2007, 11:53 |
Re: nozzle boundary condition
Check your boundary conditions, in the subsonic case you need one source of information coming from the outlet. Static pressure for example. With the rest coming from the inlet, in 1D there are only 2 left, so let's say for example total pressure and velocity.
September 23, 2007, 20:23 |
For the subsonic case, I fixed P at the outlet and while letting rho, and u float. For the inlet I fixed rho and P and u.
I read from Anderson (modern compressible flow with historical perspective) that using the method of characteristics you should let one variable float (ie.u) at the inlet. i tried this and the solution was wrong. Why is this? Shuo |
September 28, 2007, 06:59 |
In the subsonic 1D case, try:
Fixing on the outlet: static pressure Fixing on the inlet: total pressure, temperature and velocity |
September 28, 2007, 07:28 |
Yep, it's working. Thanks Shuo
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
