SIMPLE, SIMPLER or PISO?
Old   October 16, 2007, 17:37
Default SIMPLE, SIMPLER or PISO?
Gem Leku
Hello
How do you choose between the algorithms SIMPLE, SIMPLER or PISO?
Are there any guideline somewhere? Can someone draft a recommendation?
Thanks in advance
G.L.
ps: I noriced you can search for CFD users on http://www.linkedin.com
Old   October 18, 2007, 04:29
Default Re: SIMPLE, SIMPLER or PISO?
George
PISO is the more robust from the three algorithms. But it is a little bit more complex to implement. But in some cases the convergence is 20-50% faster.
If I were you, I would choose PISO. It worth the extra trouble of incorporating the extra terms.
SIMPLER on the other hand is a little bit faster than SIMPLE and it is extremely easy to implement. Just change a coefficient of the SIMPLE algorithm.
hope it helps
Old   October 18, 2007, 23:44
billpeace
For compressible NS equation,which one are used?
Old   October 22, 2007, 04:59
George
I am sorry for a mistake in my previous message. In SIMPLEC there is only a change in a coefficient, while SIMPLER is a bit more complicated.
All can be used for compressible flow.
Old   October 23, 2007, 23:27
billpeace
Are there any introduction on solving compressible flow by SIMPLE or other three algorithms? I know how to implement simple algorithm for incompressible flow,but add a energy equation for compressible flow. How to deal with the addition equation?
thanks
Old   October 24, 2007, 04:50
George
You just compute density with the ideal gas law or any other law. And ofcourse the incoming flow rate does not equal the outcoming flow rate as in incompressible flows.
Old   October 24, 2007, 09:09
ag
Well, not quite. You do need to also solve the energy equation (typically the enthalpy equation is used.)
Old   October 24, 2007, 11:20
opaque
Dear George,
Careful on:
"And ofcourse the incoming flow rate does not equal the outcoming flow rate as in incompressible flows."
Mass must be conserved. Therefore, for steady state calculations, the incoming mass flow must be identical to the outgoing mass flow.
Int_over_allboundaries (density * velocity) dot dA = zero
Opaque
SIMPLE (or SIMPLER) fortran code Francesco Di Maio Main CFD Forum 6 January 18, 2017 04:59
SIMPLE OR SIMPLER algorithm Sergio Costa Main CFD Forum 2 July 29, 2007 06:44
SIMPLE and PISO Aditya Main CFD Forum 5 April 1, 2006 18:52
SIMPLE and SIMPLER code TAW Main CFD Forum 10 August 25, 2005 06:09
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
