Continuity Equation
Old   October 25, 2007, 03:42
Default Continuity Equation
selim
Hi, I ran a simulation in a CFD code. When I monitor the continuity equation in the computational domain I see some regions are much greater than zero? Is there something wrong or could it like that in a numerical simulation?
I am quite new to CFD Thanks, selim
Old   October 25, 2007, 04:10
Default Re: Continuity Equation
mic
Do you mean that you are monitoring the residuals of the continuity equation? If this is the case, the residuals are greater than zero but must be of the order of e-3, e-5 (depends on the code you're using and the simulation type)
Old   October 25, 2007, 04:17
selim
Thanks for the answer
I am performing an incompressible cold flow simulation.
What is residual? (Continuity is not zero at each point of the domain? e.g delta(u)/delta(x) +delta(v)/delta(y)=0?) or not? At some points this exceeds 10,-10
Any further suggestions ,
Kind regards, selim
Old   October 25, 2007, 05:29
Hatef
Hi Residual means the diffrence between two last iterations. for instance if you are monitoring the continuity which is simply the mass flow rate and you are getting a resdiual of the order of 10e-10 which is really a good order... then it means that the difference in result of last two iterations is of order of 10e-10. this is not a very accurate definition but it helps you to get some idea about residual.
Old   October 25, 2007, 06:25
mic
Yes, what Hatef says may help you understand the problem. The equation that you have to solve is the one that you mention, but this is not directly integrated. And the residual is the indication of how good is your solution E-10 is really wonderful! What is important, is to verify that the massflow that enters your domain is equal to the mass flow that exits from your domain.
Old   October 25, 2007, 09:01
selim
Hi, I undertstand the numerics behind CFD (Finite volume..) But actauuly what I need : I took some grid points on the rectangular domain and when I write u-momentum and v-momentum equations for this grid points, the result is quite interesting (my equations are not nondimensionalized but values are not exceptable) My question is quite simple? CFD codes give us results such that we cannot apply navier stokes equations in every point. It is satisfied globally(like an overall avarage) and what we see as residuals from Solver is that avarage residuals?
Is there a way to extract points (grid points) such tjhat NS is applicable to that points?
May be I am wrong
Please correct me
Thanks Selim
Old   October 25, 2007, 09:49
momentum_waves
Perhaps you have a leak in your system?
Seriously, though, do you have any mass source terms in your model?
mw...
<www.adthermtech.com/wordpress3>
Old   October 25, 2007, 10:48
agg
The equations must be satisfied at each and every point/control volume, not just globally. When you are evaluating the continuity equation (du/dx+dv/dy), make sure you are computing the derivatives correctly (depending on whether variables are cell centererd or face centered etc.)
Old   October 26, 2007, 01:05
Shuo
Does the continutity condition reach a very small value for flows that are unsteady or periodic in addition to steady flows?
Old   October 26, 2007, 09:01
ag
If the flow is incompressible then the divergence-free condition should be enforced whether the flow is steady or unsteady. In an incompressible, segregated solver div(u) = 0 needs to be satisfied locally at the end of each iteration. This leads to the pressure corrections in terms of the intermediate veloctiies, and basically ensures that continuity is also satisfied.
Old   October 26, 2007, 18:06
  #11
shuo
How about compressible steady and unsteady flow?
Old   October 26, 2007, 18:08
  #12
shuo
Also is continuity satisfied for finite difference schemes locally?
Old   October 27, 2007, 15:14
  #13
ag
Continuity is always satisfied, but for a compressible flow the divergence is not zero. In a segregated scheme one would solve for the density variation using the continuity equation after computing the pressure corrections (at least that is one approach).
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
