Doubt - Multiblock coding
Old   December 1, 2007, 01:36
Default Doubt - Multiblock coding
Abhishek
Dear Members, I m developing 3D-NS code using Fortran language.. I am facing problems with multiblocking .... I am unable to understand , how to declare global variable in "data type". I am using "module" and then defining "type" within the module. If i try to use "common" statement than I have to specify the array size also and then i will not be able to use dynamic memory allocation. In the fortran text available , they generally, in refernce examples call the "subroutines" by passing variable. Is doing this a good option ??? How do i achive passing variables within subroutines ... Please help me regarding this ..
Thanks in advance. Abhishek
Is CFD coding in finite element method a formidable job? bearcat Main CFD Forum 0 June 18, 2010 20:53
Multiblock ctructured grids in CGNS-format Beaver Main CFD Forum 0 April 4, 2010 06:58
Ground coding enquiry Wenqing Zhang Phoenics 2 August 12, 2002 11:56
User coding on NT w2k Philip Jones Siemens 0 November 26, 2001 03:43
multiblock to create cylinder tube ? olivia FLUENT 1 February 2, 2001 00:25
