Open Channel turbine simulation, cell zone moving randomly
Like Tree1Likes
  • 1 Post By arjun
Old   October 5, 2022, 14:14
Post Open Channel turbine simulation, cell zone moving randomly
Brunei-Muara
CFDnub is on a distinguished road
Hello users,
I am writing a thesis on open channel axial water turbine simulation.
As for the setup, i am using transient, VOF (air and water) open channel, k-e RNG model, standard wall fn.
I have set up everything else normally such as the free surface level and boundary conditions such as pressure inlet, pressure outlet, and another pressure outlet at the top surface.
For geometry,
I have 2 domains, one stationary and one rotating domain for the turbine.
Both are set with numerical beach, with the stationary domain using frame motion and the rotating domain using mesh motion with the setup seen in the picture.
After running the simulation the rotational domain translates from its original location to a different random location .
Can anybody advise me on this matter please, sincerely I thank you in advance.
P.S. The yellow is supposed to be the contact region between the stationary and rotating domains
CFDnub is offline   Reply With Quote
Old   October 6, 2022, 23:48
Brunei-Muara
thousand users in this forum, but nobody is answering. I guess y'all fking trash at this too
Old   October 7, 2022, 01:04
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Actually you are right.
Anyway
You asked for advice so. Please do the simulation.
AtoHM likes this.
arjun is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Warning 097- AB Siemens 6 November 15, 2004 04:41
