How to get Stoichiometric Mixture fraction value of mixed fuel? |
December 25, 2014, 08:42 |
#1 | ||
Freedom
Rep Power: 12 |
Hello, forumers,
Merry Christmas! Now i want to generate the flamelet library using Cantera. But the stoichiometric Mixture fraction is required in the input file. The library is generated by a counterflow flame. The fuel side is : Quote:
regards, wenxu |
April 4, 2015, 07:16 |
please help me!
#2 | |
Dear Wenxu
i have problem at the same. i want to run ./flamelet for biodiesel liquid fuel. there are two problems. first: calculation Stoichiometric Mixture fraction (Zst) in input.txt. second: who can i implement the initial condition file for my fuel ( solution.xml). if you deal with please let me know the guidline. Thank you Farhad Quote:
April 4, 2015, 08:11 |
Freedom
Rep Power: 12 |
Dear Farhad,
1) First there are many definition for mixture fraction (as far as I know, at least four!), here for mixed fuel, the Bilger's definition is suggested.-----Based on element. 2) Now I use FlameMaster to generate flamelet library. I am not very familiar with the developed Canter code. But I know that the solution.xml is the start file for calculation flamelet equations and it is based on gri.30 (you know?) So you can use this file if you also want to use gri.30 as your mechanism. Hope this helps, regards, wenxu |
April 4, 2015, 10:09 |
Dear sir
i found the Z(st) formulation from RWTH university paper. as you mentioned, in counterflow software are 2 samples , H2O2 and CH4 case gri3.0 is related to CH4 but my fuel is liquid and has different mechanism. anyway, my prof. suggest me to use Flamemaster.but i used CHEMKIN for creating tables. dose the Falmemaster easy to use and installtion on linux? |
April 4, 2015, 10:33 |
Freedom
Rep Power: 12 |
Not easy to use for newers but easy to install. Anyway, it is a promising tool to generate flamelet library.
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
mixture fraction | Sheng Chen | Main CFD Forum | 0 | October 6, 2004 01:33 |
