Data Visualization
Old   March 9, 2008, 09:15
Default Data Visualization
Ahmed
Has any one on this forum downloaded and successfully installed and run the programme OpenDX (www.opendx.org)on a windows system, I would like to know which X server has he installed. Thank you for your comments
Old   March 9, 2008, 14:10
Default Re: Data Visualization
CFD_novice
One way is to install Exceed in your computer. The following is the quote from its README file:
" If you are running Exceed 7.0 or newer, there is a conflict with some of the dynamic link libraries DX may install, however, the installer will not install these if Exceed 7/8 is detected. If you have problems running OpenDX with any version of Exceed, make sure that the "Non Exceed Libraries" are not installed. To check this, run the OpenDX Installer and choose modify. Here you can see the "Non Exceed Libraries" option and make sure they are not installed. "
Please correct me if I am not correct.
Old   March 9, 2008, 14:20
john
i do not know about native windows version but you could install cygwin (full instalation include X) and then install cygwin version of DX, it works well based on my experience (do not forget "xinit" command in cygwin to switch to graphic mode prior to run DX)
Old   March 9, 2008, 19:41
CFD_novice
I installed Exceed. My problem is that the image window flashed and was gone when I click "visualize data". So I can not see the image window. I tried two computers and same thing happened. Does anyone know how to fix this problem?
Thanks.
Old   March 15, 2008, 16:02
Ahmed
Thanks John for your reply, I have found the following site helpful when installing cygwin http://www2.warwick.ac.uk/fac/sci/mo.../cygwin/part1/ the command to start an X server is startxwin.bat, xinit opens a graphic window that conflicts with dx, after that typing dx in the cygwin window calls the programme. Looks an interesting tool
Visualization a set of data using iso-surfaces MrMcMahon Main CFD Forum 2 July 6, 2010 11:44
Visualization of Data - IFriT Ahmed Main CFD Forum 0 July 2, 2009 11:47
OpenFOAM native format data visualization and workflow zeliboba OpenFOAM Post-Processing 0 September 12, 2008 08:44
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
The program for the data visualization in Linux ztdep Main CFD Forum 8 June 29, 2005 09:21
