Solid EOS
Old   March 16, 2008, 14:55
Default Solid EOS
adam
Hi
I need EOS for a Solid phase. Can some one introduce an EOS in the form:
P = ?????
i.e. an EOS similar to the ideal gas. Am modeling a mixture of gas-solid two-phase flow, 1-D.
Thank you for your help and guidance.
Old   March 17, 2008, 16:42
Default Re: Solid EOS
jinwon park
See the stiffened gas EOS. This provides parameters for various media which are solid, liquid and gas. Good luck.
Jinwon
Old   March 17, 2008, 16:47
jinwon park
Or you can also see the Gruneisen EOS. The stiffened gas EOS is a reduced form of the Gruneisen EOS.
Old   March 18, 2008, 02:57
adam
i have looked to Gruneisen EOS but i couldn't derive a formula for:
P = .........
can we use the ideal gas EOS for a solid? i.e. P = k \rho^{gamma -1}
Thanks
Old   March 18, 2008, 07:06
jinwon park
The stiffened gas EOS is able to be recast as it.
Old   March 18, 2008, 13:12
adam
Many thanks for your reply. I hope you, or any one out there, will help me about the following. The EOS is:
e_{k} = \frac{P_{k} + \gamma_{k} P_{0}}{\rho_{k} (\gamma_{k} - 1)} where k = g (gas), s (solid)
* For the GAS phase I have taken:
P_{g} = K_{g} \rho_{g}^{(\gamma_{g} - 1)}
with P_{0} = 0
** what shall I use for the solid phase.
P_{s} = what............. ?
Am doing mathematical analysis for a compressible mixture of gas-solid two-phase flow in 1-D only.
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
SPH elastiuc solid EOS rubenparedes Main CFD Forum 0 January 25, 2011 16:03
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
