CFD software for hypersonic flows
Old   May 12, 2008, 13:56
Default CFD software for hypersonic flows
Steve Scotts
Hi
I'm looking to run RANS-based CFD for hypersonic flows.
I'd like a software to use that allows me to implement my own turbulence models.
My current options are Fluent, GASP, and CFD++
My question is does it matter which one I use or should all of these be appropriate? Are there any roadbumps in using Fluent for this?
Thanks
Old   May 13, 2008, 08:48
Default Re: CFD software for hypersonic flows
Andy R
Steve, I use both GASP and FLUENT. When I can I prefer GASP from a physics capture standpoint. It has a much longer history within the high speed flow community. It clearly does a better job capturing weaker shocks and expansion waves. It seems to have a better set of wall treatments for compressible flow and BL shock interaction.
That said it requires a strict multi block grid (though it allows poles) and it does not yet fully support droplet injection (at least to fluents level) and it has no "mixed is burned" type of combustion model. I do use FLUENT when necessary.
Be aware that certain components of GASP are export controlled.
I do know of people using CFD++ succesfully but have no personal experience. I have also heard that STAR-CCM is capable of modeling these flows.
A caveat If your flow is such that gas dissasociation effects will be important say something above the mach 7 to 9 range, than you really need something like GASP, its thermodynamic models are significantly more sophisticated. There is also a "free" code out there called VULCAN from NASA.
Hope this helps -AndyR
Old   May 14, 2008, 19:29
Vedat Akdag
Steve:
I work for Metacomp Technologies, developer of CFD++. If you need technical support from us regarding setting up a hypersonic flow case please let us know. Contact support@metacomptech.com
Hope we can help.
Vedat
Old   May 19, 2008, 18:14
Librarian
CFD++ only works on windows and not large clusters, is this right? are there performance test on large linux cluster?
CFD price comparison antbot Main CFD Forum 10 August 21, 2007 21:04
Student looking for CFD software Chris Main CFD Forum 6 January 21, 2005 03:20
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Suggesst a CFD software Dr.Ing.Jameel Ahmed Khan Main CFD Forum 1 May 20, 1999 14:41
educational software package recommendations Allan Morrison Main CFD Forum 5 April 5, 1999 12:07
