February 28, 2013, 05:09 |
2D Adiabatic Compression
Oku
I'm trying to simulate a flows in in-cylinder compression(layering and re-meshing method) using the rectangular mesh after previewing the mesh motion,i realized that the mesh after compression does not look like the mesh before compression that is the cell volume looks elongated.In a simulation like this can somebody tell me how the nature of the mesh would look like and the proper dynamic mesh parameters.
April 23, 2015, 00:48 |
sanjeet Limbu
Rep Power: 11 |
hi
I am trying to compress the closed volume cylinder with fluid inside as fuel mixture using piston motion. the compression time is 30ms and I am seeing the pressure/density rise, but unable to get any temperature rise. I am using the 2D axi-symetric mesh for the cylinder compression |
April 23, 2015, 06:23 |
Oku
Can i know your set for the problem maybe your case files before i could diagnose the problem. |
Adiabatic compression | Erik | Siemens | 4 | February 21, 2016 23:56 |
coldEngineFoam (OpenFoam 2.1.x), constant Temperature during adiabatic compression | novakm | OpenFOAM Verification & Validation | 1 | February 25, 2013 12:25 |
File needed for fluent tutorial: 2D Adiabatic Compression (Remeshing and Spring | nha1g08 | ANSYS | 0 | March 30, 2011 15:40 |
Problems with non adiabatic PDF! | Christoph_84 | FLUENT | 0 | November 17, 2009 09:55 |
Adiabatic compression caused by gas ram | Chris | FLUENT | 0 | December 13, 2005 04:42 |
