udf in parallel
Old   May 27, 2015, 11:23
Default udf in parallel
yanboliu
yanboliu is on a distinguished road
Hello all:
I have a simulation that requires apolynomialTemperature at the inlet. In order to do this I have written the udf shown below and it can work well for serial operation,but when i try to load it for parallel implementation. I have found it appear error shown below.
Thanks all in advance for any help provided.
#include "udf.h"
#include "math.h"
DEFINE_PROFILE(unsteady_temperature, thread, position)
real t, temperature;
face_t f;
begin_f_loop(f, thread)
t = RP_Get_Real("flow-time");
temperature = 295.869+5.3462*pow(10,-18)*pow(t,4)-6.3431*pow(10,-13)*pow(t,3)+1.2431*pow(10,-8)*t*t+0.00042227*t;
F_PROFILE(f, thread, position) = temperature;
end_f_loop(f, thread)
cpp -I"C:\Program Files\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\Program Files\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\Program Files\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\Program Files\ANSYSI~1\v140\fluent\fluent14.0.0/mult
port/src" -I. -DUDFCONFIG_H="<udfconfig-host.h>" "C:\Users\Administrator\Desktop\udf unsteady temperature s.c"
C:\\Users\\Administrator\\Desktop\\udf unsteady temperature s.c:2: math.h: No such file or directory
999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The Parallel FLUENT process could not be started.
yanboliu is offline   Reply With Quote
Old   May 28, 2015, 11:31
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Two suggestions:
1) try to move "face_t f;" before the "real" declaration
2) try to get the flow time as "t = CURRENT_TIME;" Indeed, note that the manual suggests:
"You should not access a scheme variable using any of the RP_GET_... functions from inside
a cell or face looping macro (c_loop or f_loop). This type of communication between the
solver and cortex is very time consuming and therefore should be done outside of loops."
sbaffini is offline   Reply With Quote
"Define_Profile" UDF for parallel solver Antoine Fluent UDF and Scheme Programming 9 February 29, 2016 06:09
Problem in using UDF in parallel computing Yogini Fluent UDF and Scheme Programming 0 January 22, 2013 08:23
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 07:33
Parallel UDF Error Andrew FLUENT 2 March 30, 2007 11:11
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
