Diffusion term: L. Davidson, H.Jasak, M.Peric
Old   June 30, 2008, 13:30
Default Diffusion term: L. Davidson, H.Jasak, M.Peric
Michail
Dear colleagues
I am writing code for solving general transport equation by finite-volume method on non-orthogonal grids
I have difficulties with discretisation of the diffusion term on non-orthogonal grids.
I have the following literature
1) M.Peric "Computational methods for fluid dynamics"
2) Doctor of Philosophy thesis by Hrvoje Jasak
3) Calc-BFC description by Lars Davidson http://www.tfd.chalmers.se/~lada/allpaper.html
4) Numerical Methods in Heat, Mass, and Momentum Transfer by Jayathi Y. Murthy
5) Darwish, Marwan (2003), "CFD Course Notes", Notes, American University of Beirut. http://webfea-lb.fea.aub.edu.lb/CFD/presentations.htm
But I still unable to understand how to fix diffusion term on non-orthogonal grids.
I fixed only orthogonal part - all is clear with it. But how to implement non-orthogonal part - all treated it differently.
I shall be very grateful for any comments and suggestions
Old   June 30, 2008, 15:44
Default Re: Diffusion term: L. Davidson, H.Jasak, M.Peric
Hrvoje Jasak
What seems to be the problem:
1) on each finite volume face, make matrix coefficients using:
mag(face_area)*gamma_face*(phi_N - phi_P)/distance.
Thus, to che central coefficient add:
-mag(face_area)*gamma_face/distance
and to the off-diagonal coefficient add:
For non-orthogonal correction, interpolate grad(phi) on the face and calculate non-orthogonal correction. This will be the bit that you did not put into the matrix:
face_area dot grad(phi)_face - mag(face_area)*gamma_face*(phi_N - phi_P)/distance
This goes into the right-hand side... and you are done!
Got it?
Hrv
Old   June 30, 2008, 16:25
Michail
Dear Hrvoje
Thank You very much for Your responce
But I am still a bit confused
How to implement "face_area dot grad(phi)_face" in program?
should I derive face_area and grad(phi)_face as cartesian projections and then put it into the sourse term?
I would like to get something like that (for 2D structured grid, east face):
Koeff_eta (phi_en - phi_es) where phi_en = 1/4(phi_N+phi_E+phi_P+phi_NE) and phi_es = = 1/4(phi_S+phi_E+phi_P+phi_SE)
then I'll put the appropriate parts of coefficint into the central, east, and source terms
Excuse me for such non-math thinking.
I completely lost myself in covariant and contrvariant components, because of white spots in my education.
Thanks in advance, Michail
Old   July 1, 2008, 02:59
diffusion term
have a look at the wiki page at cfd-online , that also summerise what jasak said.
Old   July 1, 2008, 05:43
Michail
I looked there.
The question is:
How to express this in cartesian coordinates?
Non-orthogonal part.
Old   July 1, 2008, 09:32
John
I recommned to look at Mikhail Shashkov's publication on this subject, there u find a very fine method in particular dealing with highly irregular (non-orthogonal) grid, and particularly hex/quad grid.
URL: http://cnls.lanl.gov/~shashkov/
e.g.: http://cnls.lanl.gov/~shashkov/papers/brezzi_07.pdf
http://cnls.lanl.gov/~shashkov/paper...monotoneFV.pdf
http://cnls.lanl.gov/~shashkov/papers/mixed_cells.pdf
good luck
Old   July 1, 2008, 19:48
diffusion term
if you use the vector notation things will be okey. Further since it is cartesian mesh , the non ortho term shall be zero.
Old   July 2, 2008, 06:04
Michail
The problem is that I use non-orthogonal grid and cartesian components of coordinates and velocities.
The grid is non-orthogonal
And I don't know how derive this from vector notation
Old   July 2, 2008, 08:06
Hrvoje Jasak
Forget about local coordinates. Express face normal as a global Cartesian (x y z) vector, do the same with the gradient and do a dot-product in global Cartesian coordinates.
I promise, this is not too hard. You just got confused by some side-issue.
Hrv
Old   July 2, 2008, 14:03
Michail
Thank You, I'll try...
Old   July 2, 2008, 21:54
  #11
diffusion term
its really easy:
you have cell centers on either side of a control volume face. (x0, y0, z0) and (x1, y1, z1)
then you have face center like fx fy fz, and then there is one more thing, which area vector of the face Ax Ay Az.
Then just look at the formula given in wiki page, construct the relevent vectors. Add the diagonal and off diagonal contributions to their respective places. Add the nonortho correction to source. And you are ready to go.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
FVM discretization of diffusion term on crvlnr gr Michail Main CFD Forum 3 March 14, 2008 06:52
secondary diffusion term Steve Moore FLUENT 9 September 7, 2005 23:14
