LES cut off wave number
Old   June 14, 2008, 01:53
Default LES cut off wave number
Fab
does anyone know, how to calculate the cut-off wave number of the energy spectrum when using an implicit mesh filter?
Thanks! Fab
Old   June 14, 2008, 06:47
Default Re: LES cut off wave number
cfd.novice
I think its same as your grid size. But I am not sure, I hope some one with more experience can confirm this. How are doing your energy spectrum? Can you please explain the process.
Old   June 15, 2008, 13:42
Fab
it is probably an easy answer, when one has a cartesian aequidistant mesh, as the cut off would be 2*pi/deltaX !? With deltaX the cell size, but what can be used to for unstructured meshes!?
For a temporal energy spectrum I would do 'just' an fft of a the velocity tracked at a certain point. For the spatial spectrum I just can think of a correlation!?
Fab
Old   June 16, 2008, 15:42
cfd.novice
Which software did you use for it? Do you mind if I have a look at the code you wrote for it. I am interested in temporal spectrum. Thank you in advance
cfd.novice
Old   July 2, 2008, 19:39
krish
can you explain me how did you track the velocity? what was ur initial condition?
I did FFT on the velocity data that i have been given but it is not showing the energy spectrum that i see in the technical journal papers.
I think the data i got is wrong.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
Number of nodes for LES And DES mohammad Main CFD Forum 4 May 15, 2011 00:31
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
cut wave Julian CFX 1 April 30, 2007 13:36
