larminar flow doesn't change into turbulent flow
Old   September 3, 2008, 03:31
Default larminar flow doesn't change into turbulent flow
dh
hi
i'm coding unsteady rans channel flow(k-epsilon, Ret=180) but turbulence doesn't appear. it converges larminar flow..... i don't know why it does. i need your help.
Old   September 5, 2008, 21:04
Default Re: larminar flow doesn't change into turbulent fl
sensor
Here are two possibilities:
(1) your algorithm is overly dissipative (which is not a good situation);
(2) Keep in mind: larminar flow is a possible solution to the NS system. Add much larger random fluctuations to your initial field, and then let the field gradually converges to a steady state turbulent field.
Old   September 6, 2008, 21:08
d.h.
Hi Thank you for your response.
It seems that my case is (1) among possibilities you give.
May I know the ratio nu(kinematic viscosity) to nut(eddy viscosity)? And I want to konw the initial condition of kinetic energy(k) and eddy dissipation ratio(epsilon).
Old   September 11, 2008, 23:32
sensor
Sorry I thought you were doing LES or DNS. But, in any case, do not give up easily. Since you are using k-epsilon model, I assume it is steady RANS. Check you k- and epsilon-equations and also the eddy viscosity model, and see if they are coded correctly. Check, e.g., the calculation of the strain rate tensor.
The case of Re_tau=180 is a very classical one. You can find the ratio between nu and nu_t in, e.g., ``Turbulent Flows'' by S. Pope. If I remember clearly, nu_t/nu is about 36 at the center of the channel.
Just my curiosity: if this is for basic training (e.g., course study), it is fine. But if this is for your PhD research, not good. You should be provided a basic code which can do this classical benchmark test case, at least. Otherwise,,,
Old   September 26, 2008, 01:29
dh
Thank you for your advice~ Actually I have studied hybrid RANS-LES model. Unsteady problem is terrible thing itself..... T T Now turbulence is generated thank to your help but the result is not good. I want to know the periodic boundary condition for pp. When soving Poisson eq., how are coefficients, ae, aw(steamwise direction), ad, au (spanwise direction) treated for SIMPLE algorithm?
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 01:00
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 03:03
