September 3, 1998, 11:24 |
wall-laws for k-epsilon and velocity
I am trying to solve the flowfield through a heatsink channel and have simpified the equations to flow against the plane only one velocity component + k and epsilon. The flow are driven by a pressure gradient. I 'am using the time to solve for the third dimension. I'am wondering if anybody now of good wall-laws for u,k,eps that can be used for his type of problem.
September 10, 1998, 10:05 |
Re: wall-laws for k-epsilon and velocity
Hello Ola
I represent a software company called FLOMERICS LTD. We specialise in developing software to solve electronics cooling problems using CFD. Our premiere product is called FLOTHERM, it is the most widely used software package of it's type (~85% market share - worldwide). You might be interested to learn more about FLOTHERM as a lot of the applications involve heatsink flow and heat transfer. In the first instance please visit our website, www.flomerics.com We have a list of technical papers within the FLOTHERM technical literature pages. Some of these papers may be of interest to you in solving your problem. Please contact me if you require any further information, Kind Regards, Andrew |
September 10, 1998, 10:14 |
Hi Andrew!
What kind of wall-laws would Flomerics recommend then? Are you only using wall-laws in your codes or do you have any other alternatives? Perhaps you could give some details on how you have implemented the wall-laws? |
September 10, 1998, 11:21 |
Pete,
Flomerics uses a novel treatment to modify the eddy viscosity as you move away from a wall based on the local y+ and u+ variation. Heat transfer from the wall surface is based on standard Stanton number relationships coupled with Jayatilleke's resistance functions. The advantages of our wall function treatment is available to any user of Flotherm. Regards Dr. Robin Bornoff Consultant Engineer Flomerics Ltd. |
Wall function for velocity? | johnblund | OpenFOAM | 3 | September 6, 2022 07:22 |
Wall functions for near wall treatment : k - epsilon model | fivos | Main CFD Forum | 4 | April 27, 2011 07:44 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
how to print the results from CFX-4.2 | cfd_99 | Main CFD Forum | 5 | June 21, 1999 09:23 |
