how to specify the inlet turbulence kinetic energy
Old   December 3, 2005, 04:26
Default how to specify the inlet turbulence kinetic energy
rajesh
Can any body please help me how to specify inlet boundary condition for turbulent flow. Because it is asking for parameters like turblence reference velocity, % mean velocity, % hydraulic diameter, turbulence kinetic energy, turbulence dissipation rate.
Old   December 3, 2005, 06:00
Default Re: how to specify the inlet turbulence kinetic en
Rashmi
hi can u tell me what u r modeling so that i can answer ur question
Rashmi
Old   December 3, 2005, 06:16
rajesh
i am trying to model water cooling jacket of a diesel engine, for that i need inlet specifications. i know the mean mass flow rate and pressure. thank you
Old   December 3, 2005, 18:52
Halim
The followings are what the CFX code is doing;
TEin=1.5*(0.037*Vin)**2,
EDin=TEin**1.5/(0.3*D)
where TEin is the turbulent kinetic energy at inlet, EDin is its dissipation rate at inlet, Vin is the inlet velocity and D is the inlet length scale such as the hydraulic diameter. The value 0.037 (3.7%) is the turbulence intensity and you can change it. I hope this helps.
Good luck,
Halim
Old   July 29, 2015, 07:27
Siddhant Jain
jainsiddhant19@gmail.com is on a distinguished road
Can u please tell me the source of above info
jainsiddhant19@gmail.com is offline   Reply With Quote
LES and total turbulent kinetic energy Boerge FLUENT 1 September 8, 2012 11:41
LES of periodic pipe centerline turbulent kinetic energy smehdi609 OpenFOAM 0 November 30, 2010 23:59
Turbulence kinetic energy transfer Jun FLUENT 0 April 11, 2006 23:52
turbulence kinetic energy profile chouer Main CFD Forum 0 October 27, 2005 22:02
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
