August 4, 2015, 12:23 |
A Problem with my OpenFoam animation
Mike
Rep Power: 15 |
Hi there,
I am new to OpenFoam and just started working with that. I have conducted a test on a 2D cylinder at Re=100 (laminar), just to make sure that the basics of my openfoam simulation are OK. The simulation went well and I also made an animation for the flow evolution which can be downloaded from here: https://www.dropbox.com/s/zqnvxg7hbt...-SLOW.avi?dl=0 There is some thing that puzzles me a bit. Although it is quite obvious from the contour structures and topology that the flow is from left to right, in the animation it seems that those high U contours are begin convected from the outflow boundary to the cylinder. It is not a visual mistake as I refined the time step and got the same result. I suspect there might be some more subtleties related to OpenFoam. I checked whatever I knew but could not find the problem. If I ran the animation in the reverse order then it looks quite nice! I'd appreciate your help. Last edited by saeedi; August 4, 2015 at 14:06. |
August 4, 2015, 13:55 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Are you sure that you have the correct order of the zones in Tecplot? It seems simply reversed ... |
August 4, 2015, 14:04 |
Mike
Rep Power: 15 |
Yes,
I checked it. It seems that the timestrands are correct and in the right order. |
August 4, 2015, 14:07 |
Rep Power: 71 |
try to do the animation with a vector plot, it could be more useful
August 4, 2015, 14:10 |
Mike
Rep Power: 15 |
August 4, 2015, 14:15 |
#6 | |
Rep Power: 71 |
it still seems the order of the zones is reversed.... |
August 4, 2015, 14:20 |
Mike
Rep Power: 15 |
But if you look at the flow development, from time=0 to the first couple of snapshots, it shows that the flow is developing correctly and I think that is an indication that the zone order is right. But suddenly we see that reverse behaviour around time=1.
Also, when I do it in tecplot frame by frame, the time associated with each snapshot and their orders are OK. It is really strange. |
August 5, 2015, 13:15 |
Mike
Rep Power: 15 |
No more idea?
August 5, 2015, 13:22 |
#9 | |
Rep Power: 71 |
I suspect that we are victim of some optical joke due to the movie... I tried to see each frame of your movie and it seems to work fine |
August 5, 2015, 13:24 |
#10 |
Rep Power: 71 |
you know, depending on the sampling frequency we can have a sort of stroboscopic effect....
August 5, 2015, 13:27 |
#11 |
Mike
Rep Power: 15 |
That came to my mind as well.
But when I refined the time-step and consequently the writing interval by 4 times, I still observed the same thing. |
August 5, 2015, 13:44 |
#12 |
Rep Power: 71 |
August 5, 2015, 13:46 |
#13 |
Mike
Rep Power: 15 |
Yes I did.
Same thing. That's Why I always prefer to use my own code. It is way easier to track. |
Can OpenFoam solve this problem? | salazardetroya | OpenFOAM Running, Solving & CFD | 1 | July 29, 2015 22:34 |
Problem when installing Openfoam 2.0.x with mac | giovaniharyadi | OpenFOAM Installation | 0 | March 24, 2012 18:45 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
