pressure drop
Old   September 24, 2008, 05:34
Default pressure drop
jay
Hi all I have one system (take water jacket as an example). and I do CFD analysis by defining pressure outlet (say 2 bar) and get some pressure drop (say 25 %). Now if I change this outlet pressure (say reducing to 1.5 bar), then will I get reduction in pressuredrop??? pls let me know, if any one has idea. my query is if I reduce outlet pressure then will it reduce my overall pressure drop??? On which parameters overall pressure drop depends???
Thanx all for taking interest.
Old   September 24, 2008, 09:27
Default Re: pressure drop
wrath of god
if the flow is incompressible then the outlet pressure is irrelevent. One should get the same pressure drop across the device irrespective of the pressure you set as long as it remains incompressible.
the overall pressure drop will depend on your mass flow and the resitance to it through the device
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
